Cannot write modification time to my phone's SDXC card
bezzerkk
So, I have all my music files - currently around 16000 files - on a my local LAN's Linux server and wish to sync them all to my new mobile phone's 256GB SDXC card.
For syncing I use the latest Freefilesync v14.3 installed on my Windows 10 PC that is also connected to my LAN. I compare using "File time and size" and then synchronize using "Mirror". The phone(s) is connected to my Windows PC using a USB-c cable.
With my former old phone - a Xiaomi MiA1 Android v9+Aug 2020 security update (internal storage formatted as EXT4FS with 4kB blocks) having a 128 GB Kingston Canvas Go1 Plus SDXC card (came formatted as VFAT/FAT32 with 32kB blocks) - there is/was no problem syncing.
But alas with my new phone, a Samsung Galaxy A16 LTE/4G 8GB/256GB with Android v15+May security update (internal storage formatted as F2FS with 4kB blocks) I'm flooded with get the dreaded warnings:
Cannot write modification time of "mtp:\\Galaxy A16\SD card\Music\........ .ffs_tmp"
whether I write to the SD card's EXFAT area or to its internal 256GB F2FS storage.
Now, my newly bought Kingston Canvas Select Plus SDXC 256GB card came formatted as EXFAT. So I now wonder if reformatting the card to instead using the old FAT32 then maybe Freefilesync updating file modification times would work again. Though to try this I first need to buy a SD card reader but before I'll do that I try asking the esteemed forum members on their views and opinions on the matter. Has anyone got file syncing working using a **FAT32** SD card?
Regards,
Bezzerkk
John1234
Files by Google and format your SD card into fat32 or exfat for your testing purposes
📦 Play Store: Preinstalled or search “Files by Google”
⚙️ Format: Only reformats to internal-compatible formats (usually FAT32 or exFAT)
👤 Root Required: ❌ No
🛠 You can use it to erase and format SD cards for portable or internal storage.
📍 Go to: Settings > Storage > SD card > Format
bezzerkk
Thanks - I downloaded "Files by Google" and formatted my SD card. There is however no option to choose between SDFAT (=FAT32 ?!) or EXFAT before formatting. Seems though it always (?) chooses SDFAT by default.
However SDFAT did unfortunately not help as I still get the "write modification time" warnings.
So, seems I have no choice but to compare to "File size" instead... :-(
EDIT: SDFAT is a library that supports FAT16, FAT32, and exFAT file systems on Standard SD, SDHC, and SDXC cards.
=> Means I don't know if my card now is formatted as FAT32 or EXFAT!!
John1234
On Android, when you format an SD card using the system settings, the default file system format used depends on:
1. Card size
≤ 32 GB: Formatted as FAT32
> 32 GB: Formatted as exFAT
Sorry it didn't help. I have no other suggestions at this point.
For what it's worth, I've had to use File Size with my Samsung phone for YEARS now. Must be how Samsung or newer Android versions handle the protocol
bezzerkk
The only way for me to have a FAT32 formatted card is buying a card reader and connect it to either a Windows PC or Linux PC. Now Windows generally doesn't allow formatting large SD cards to FAT32 directly, so we need to use a third-party tool like FAT32 Format or Rufus. Using a Linux machine one could of course use mkfs.vfat
However it seems unlikely that even with a FAT32 formatted SDXC card the file modification warnings would go away.
NOTE: FAT32 has a 4GB file size limit, so it might not be suitable for all uses.
