Does FFS retain timestamps on folders when synchronize/mirror/update? Or is option in paid/donated vers?
Am new to FFS and read at another site that FFS does NOT retain. Need to know beforehand as cannot undo if trial&error. Thanks in advance. A
Anyone confirm? Date/Time stamps
Plerry - many thanks for answer. Not sure why did not find but used Google search. In thread, GateArray said "...use the workaround with ROBOCOPY using "/CREATE" switch to create / fix the folders date." Would you know/have instrucs on how to apply in CMD window?
SonicRings in another thread suggested command "robocopy "source" "destination" /s /copy:at /dcopy:t /timfix." It generated 3 changes when expected only 1 change. Would you know what is command, if want to apply only to specific folders? Kind regards, T
The obvious way to go, is to consult a Robocopy Manual.
I saw that too. Unfortunately, am not highly versed in writing commands. Rather not trial and error live, and then not have enough knowledge to undo results. As it were, I already got above results and not sure how got 3 changes. Thanks anyway Plerry.
My only wish for FFS: an option to preserve the correct timestamps of subdirectories.I saw that too. Unfortunately, am not highly versed in writing commands. Rather not trial and error live, and then not have enough knowledge to undo results. As it were, I already got above results and not sure how got 3 changes. Thanks anyway Plerry. Ask, 29 Jul 2025, 07:05
