Hi. This issue may be discussed already, but FileSync is showing much less number of files than Windows File Explorer. For example, FS says 74776 files (files and directories) while FE says 75335 (files and folders). Why does this happen?
Thank you for your advice in advance.
Tak
Difference in the number of files between FileSync and File Explorer
