Copy 2 levels of parent directory with files?
mlitty
I want to pull the final products of projects out of a tree into a target folder that has the project folder and the output.
It would look like this…
Source
D:*\Admissions\Undergrad Admit\output\*.*
D:*\Student Affairs\Campus Rec\output\*.*
D:*\Advancement\Alumni Affairs\output\*.*
Target
F:Finals\Undergrad Admit\output\*.*
F:Finals\Campus Rec\output\*.*
F:Finals\Alumni Affairs\output\*.*
I have hundreds of projects so manually creating each target folder would be tedious at best.
Or… does anyone know a Windows 11 terminal command that would accomplish this? I can’t install software and I can’t run as admin because it’s a work computer.
Thanks.
Perhaps I misunderstand you.
All your source references start with D:*\.
Does this mean that the path that this first * stands for can be different for each of your source/target pairs?
Is there a single path matching the * in D:*\ for each of your source/target pairs? Or can there be multiple path's matching the * in D:*\ for one or more of your source/target pairs?
When assuming all path's matching the * in D:*\ for each of your source/target pairs are the same, i.e. the path to Admissions, Student Affairs, Advancement etc. on your source (D) drive is all the same let's say D:\[PathToSourceFolderParents], I would suggest you use a single left-right pair, syncing
Left D:\[PathToSourceFolderParents] => right F:Finals\
and replace the default Include Filter of * (=everything) by \*\*\output\*.*
This assures that only the contents of your output folders that are at least two levels deep will be synced.
However, this will give you a slightly different result that you describe, as it will
Source
D:\[PathToSourceFolderParents]\Admissions\Undergrad Admit\output\*.*
D:\[PathToSourceFolderParents]\Student Affairs\Campus Rec\output\*.*
D:\[PathToSourceFolderParents]\Advancement\Alumni Affairs\output\*.*
Target
F:Finals\Admissions\Undergrad Admit\output\*.*
F:Finals\Student Affairs\Campus Rec\output\*.*
F:Finals\Advancement\Alumni Affairs\output\*.*
But may be acceptable to you.
I don't see another way to make FreeFileSync (FFS) realize your sync for you.
mlitty
Thank you for responding. You're close.
Yes, the paths are all different and the parent directories of output are all different. The challenge is that I want the different parent directories of the different output folders to copy over as well, without the full directory tree.
Here's a clearer example.
Source: directory tree ending in output\file-names.mp4
D:\administration\chancellor-office\output\speech.mp4
D:\academics\biology\output\lab.mp4
D:\campus rec\flag football\output\tournament.mp4
D:\academics\chemistry\output\classroom.mp4
Target: only the direct parent directory of output then output with its files.
F:\chancellor-office\output\speech.mp4
F:\biology\output\lab.mp4
F:\flag football\output\tournament.mp4
F:\chemistry\output\classroom.mp4
What I don't want is for all of the target files to end up in a single folder called output and I don't want the full directory trees for each file, just a single-level parent.
If this were implemented, a possible filter might be to copy
*\..\output\*.*
to indicated that the parent directory of output should also be copied over but not the directories above the parent directory of output. I haven't tried that yet but that would be one way to implement this.
mlitty
I wish FreeFileSync could do this but, in case someone else comes looking or in case it's useful to developers, I worked with ChatGPT to come up with a Windows PowerShell command that does the trick.
Get-ChildItem -Path "." -Directory -Recurse -Filter "output" | ForEach-Object {
    $parentName = Split-Path $_.Parent.FullName -Leaf
    $dest = Join-Path "F:\TEST" $parentName
    robocopy $_.FullName (Join-Path $dest "output") /E
How it works (according to ChatGPT)
• Finds all folders named output from the current folder down.
• Gets the name of their immediate parent folder ($parentName).
• Builds a destination path F:\TEST\<parentName>\output.
• Uses robocopy to copy only the contents of output to that location: outlook, it's direct parent, and the contents of output without the sibling content of output.
mlitty
