I've had FFS for a few months now, but I can not seem to get it to Sync a folder on my W11 Pro PC, to my Android's SD card.
If I take the card out and sync via USB cable directly to the card it works fine.
When I try to connect my phone via USB cable to the PC and run FFS. It finds all the files to Sync but when I actually tell it to proceed to sync it dose 6 bytes and then stalls out.
What could I be doing wrong?
Thanks for any help you can offer.
-Jaz
I need help trying to sync a folder on my pc to phones SD card.
Thanks for the link! When I first tried to search the topic, it came back with over 500 hits. Some of them were as lost as I was, and the others I felt were over my head. That being said, I attempted the SFTP server idea. I didn’t think I could do it, but it was so simple to do. I had FFS up and running on my phone in less than an hour.
Thanks again!
-Jaz
Thanks again!
-Jaz
