automated synchronisation
Denis_68
Hi Guys,
I have set the automated synchronisation for usb stick an it works.
But each time I run windows10 I get the popup asking me to start the job.
Is it the normal behaviour or could I make it done automatically ?
Should I plan it in Windows job launcher ?
thank you.
Denis
To automatically start a RealTimeSync (RTS) task, see here.
Those instructions are for Windows.
If you use MAC or Linux see here, but use the command lines as described for RTS in my first link.
Denis_68
Thank you Plerry, it works like a charm.
Denis
