Bug: FFS stumbles over own logfile
chronial
I set FFS to run in batchmode and to create logs. These logs are stored inside the folder that is to be synchronized. This causes FFS to generate the following error:
[12:08:28] Error: Cannot read file "C:\home\dotfiles\backups\logs\the-machine_internal-quick 2014-08-29 120735.log".
                  The file is locked by another process:
                  FreeFileSync - Folder Comparison and Synchronization, "C:\Program Files\FreeFileSync\Bin\FreeFileSync_x64.exe"
I could ignore the log folder in the backups, but I would prefer not to, as I would like to have backups of my old logs.
drghughes
If you're running using an administrator account you can set FreeFileSync to copy locked files.
If not, you'll need to exclude the logs from you main back up and set up a separate back up to just do the logs. As you're already running things in a batch, hopefully this won't be too much hassle.
chronial
For the moment I’m just ignoring the log file directory and it’s not important enough to create a second job for that. I just reported it here, because I think it’s a bug and should be fixed at some point. I guess FFS knows the name of its current log file and could just ignore it.
Or even fancier: if FFS notices that its logfile is part of the backup it will write it to both locations after the backup. But I have a feeling that that will be quite complicated ^^.
weberkai
Hi!
First, I would like to thank the devs for this software.
I tested with admin privileges, and I couldn't copy the log file.
So, I would like to add a suggestion:
Is it possible to create a macro %LOGFILE% and use this macro in the "exclude" rules?
If possible, can someone point me where to post this request?
Thank you!
