Linux version: complete sytem freeze
Runner86
Tested out FreeFileSync V14.5_x86_64_04.102025 on Linux Mint 22.1 to sync 2 directories on 2 different NTFS partitions on 2 different disks (from ID3 to ID1 in system information, approx. 200MB to copy/delete for the sync).
Observed:
Complete freeze of Cinnamon desktop, system completly stalled, no progress shown in FreeFileSync window. After 10 min waiting time forced hardware restart of Linux but the target disk and partition can't be mouted any more. Restarted system with WIN10 boot to verify partitions and disk but found now problems.
In fact the both directories for the test had been syncronized correctly.
Tested this multiple times with different directories but with same results.
Remark:
The WIN10 system has hibernated disabled and does always a complete shutdown before Linux is booted!
So please help me how to mount the partition for Linux again and how to avoid this system freeze on Linux.
Thank's in advance.
System information:
System:
  Kernel: 6.8.0-85-generic arch: x86_64 bits: 64 compiler: gcc v: 13.3.0 clocksource: tsc
  Desktop: Cinnamon v: 6.4.8 tk: GTK v: 3.24.41 wm: Muffin v: 6.4.1 vt: 7 dm: LightDM v: 1.30.0
    Distro: Linux Mint 22.1 Xia base: Ubuntu 24.04 noble
Machine:
  Type: Laptop System: Hewlett-Packard product: HP EliteBook 8570w v: A1029D1102
    serial: <superuser required> Chassis: type: 10 serial: <superuser required>
  Mobo: Hewlett-Packard model: 176B v: KBC Version 50.1A serial: <superuser required>
    part-nu: A7C38AV uuid: <superuser required> UEFI: Hewlett-Packard v: 68IAV Ver. F.40
    date: 01/31/2013
Battery:
  ID-1: BAT0 charge: 46.5 Wh (95.3%) condition: 48.8/48.8 Wh (100.0%) volts: 16.4 min: 14.4
    model: Hewlett-Packard Primary type: Li-ion serial: <filter> status: not charging
CPU:
  Info: quad core model: Intel Core i7-3740QM bits: 64 type: MT MCP smt: enabled arch: Ivy Bridge
    rev: 9 cache: L1: 256 KiB L2: 1024 KiB L3: 6 MiB
  Speed (MHz): avg: 1510 high: 3700 min/max: 1200/3700 cores: 1: 1197 2: 1197 3: 1197 4: 1200
    5: 1197 6: 3700 7: 1200 8: 1197 bogomips: 43100
  Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Graphics:
  Device-1: NVIDIA GK107GLM [Quadro K2000M] vendor: Hewlett-Packard driver: nouveau v: kernel
    arch: Kepler pcie: speed: 2.5 GT/s lanes: 16 ports: active: LVDS-1 empty: DP-1, DP-2, DP-3,
    VGA-1, eDP-1 bus-ID: 01:00.0 chip-ID: 10de:0ffb class-ID: 0300 temp: 39.0 C
  Device-2: Chicony Integrated HP HD Webcam driver: uvcvideo type: USB rev: 2.0 speed: 480 Mb/s
    lanes: 1 bus-ID: 2-1.3:3 chip-ID: 04f2:b230 class-ID: 0e02 serial: <filter>
  Display: x11 server: X.Org v: 21.1.11 with: Xwayland v: 23.2.6 driver: X: loaded: modesetting
    unloaded: fbdev,vesa dri: nouveau gpu: nouveau display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x285mm (20.00x11.22") s-diag: 582mm (22.93")
  Monitor-1: LVDS-1 model: LG Display 0x0259 res: 1920x1080 hz: 60 dpi: 141
    size: 345x194mm (13.58x7.64") diag: 396mm (15.6") modes: max: 1920x1080 min: 640x350
  API: EGL v: 1.5 hw: drv: nvidia nouveau platforms: device: 0 drv: nouveau device: 1 drv: swrast
    gbm: drv: nouveau surfaceless: drv: nouveau x11: drv: nouveau inactive: wayland
  API: OpenGL v: 4.5 compat-v: 4.3 vendor: mesa v: 25.0.7-0ubuntu0.24.04.2 glx-v: 1.4
    direct-render: yes renderer: NVE7 device-ID: 10de:0ffb
Audio:
  Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Hewlett-Packard 7
    driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1e20 class-ID: 0403
  Device-2: NVIDIA GK107 HDMI Audio vendor: Hewlett-Packard driver: snd_hda_intel v: kernel pcie:
    speed: 2.5 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:0e1b class-ID: 0403
  API: ALSA v: k6.8.0-85-generic status: kernel-api
  Server-1: PipeWire v: 1.0.5 status: active with: 1: pipewire-pulse status: active
    2: wireplumber status: active 3: pipewire-alsa type: plugin 4: pw-jack type: plugin
Network:
  Device-1: Intel 82579LM Gigabit Network vendor: Hewlett-Packard driver: N/A port: 5020
    bus-ID: 00:19.0 chip-ID: 8086:1502 class-ID: 0200
  Device-2: Intel Centrino Ultimate-N 6300 driver: iwlwifi v: kernel pcie: speed: 2.5 GT/s
    lanes: 1 bus-ID: 25:00.0 chip-ID: 8086:422b class-ID: 0280
  IF: wlo1 state: up mac: <filter>
Bluetooth:
  Device-1: Broadcom HP Portable SoftSailing driver: btusb v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s
    lanes: 1 bus-ID: 1-1.6:3 chip-ID: 0a5c:21e1 class-ID: fe01 serial: <filter>
  Report: hciconfig ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 4.0 lmp-v: 6 sub-v: 220e
    hci-v: 6 rev: 1000 class-ID: 7c010c
Drives:
  Local Storage: total: 1.42 TiB used: 283.84 GiB (19.5%)
  ID-1: /dev/sda vendor: Crucial model: CT1000BX500SSD1 size: 931.51 GiB speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 030 scheme: MBR
  ID-2: /dev/sdb model: BRAINZAP 64GB size: 59.63 GiB speed: 6.0 Gb/s tech: SSD serial: <filter>
    fw-rev: 3A0 scheme: MBR
  ID-3: /dev/sdc vendor: Seagate model: ST500LM000-SSHD-8GB size: 465.76 GiB speed: 6.0 Gb/s
    tech: HDD rpm: 5400 serial: <filter> fw-rev: LVD3 scheme: GPT
Partition:
  ID-1: / size: 199.11 GiB used: 122.63 GiB (61.6%) fs: ext4 dev: /dev/sdc3
  ID-2: /boot/efi size: 512 MiB used: 6.1 MiB (1.2%) fs: vfat dev: /dev/sdc2
Swap:
  ID-1: swap-1 type: file size: 2 GiB used: 0 KiB (0.0%) priority: -2 file: /swapfile
USB:
  Hub-1: 1-0:1 info: full speed or root hub ports: 3 rev: 2.0 speed: 480 Mb/s lanes: 1
    chip-ID: 1d6b:0002 class-ID: 0900
  Hub-2: 1-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0 speed: 480 Mb/s
    lanes: 1 chip-ID: 8087:0024 class-ID: 0900
  Device-1: 1-1.6:3 info: Broadcom HP Portable SoftSailing type: Bluetooth driver: btusb
    interfaces: 4 rev: 2.0 speed: 12 Mb/s lanes: 1 chip-ID: 0a5c:21e1 class-ID: fe01 serial: <filter>
  Hub-3: 2-0:1 info: full speed or root hub ports: 3 rev: 2.0 speed: 480 Mb/s lanes: 1
  Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0 speed: 480 Mb/s
  Device-1: 2-1.3:3 info: Chicony Integrated HP HD Webcam type: video driver: uvcvideo
    interfaces: 2 rev: 2.0 speed: 480 Mb/s lanes: 1 power: 500mA chip-ID: 04f2:b230 class-ID: 0e02
    serial: <filter>
  Hub-5: 3-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0 speed: 480 Mb/s lanes: 1
  Device-1: 3-4:2 info: Logitech M-U0007 [Corded Mouse M500] type: mouse
    driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s lanes: 1 power: 98mA
    chip-ID: 046d:c069 class-ID: 0301
  Hub-6: 4-0:1 info: super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s lanes: 1 chip-ID: 1d6b:0003
    class-ID: 0900
Sensors:
  System Temperatures: cpu: 50.0 C mobo: N/A gpu: nouveau temp: 39.0 C
  Fan Speeds (rpm): N/A
Repos:
  Packages: 2677 pm: dpkg pkgs: 2634 pm: flatpak pkgs: 43
  No active apt repos in: /etc/apt/sources.list
  Active apt repos in: /etc/apt/sources.list.d/official-package-repositories.list
    1: deb http: //linux-mint.froonix.org xia main upstream import backport
    2: deb http: //artfiles.org/ubuntu.com noble main restricted universe multiverse
    3: deb http: //artfiles.org/ubuntu.com noble-updates main restricted universe multiverse
    4: deb http: //artfiles.org/ubuntu.com noble-backports main restricted universe multiverse
    5: deb http: //security.ubuntu.com/ubuntu/ noble-security main restricted universe multiverse
Info:
  Memory: total: 24 GiB available: 23.41 GiB used: 2.62 GiB (11.2%)
  Processes: 312 Power: uptime: 13m states: freeze,mem,disk suspend: deep wakeups: 0
    hibernate: platform Init: systemd v: 255 target: graphical (5) default: graphical
  Compilers: gcc: 13.3.0 Client: Unknown python3.12 client inxi: 3.3.34
Runner86
UPDATE:
I've found a way to mount the partition in question again, but the problem with system freeze caused by FreeFileSync continues.
Runner86
UPDATE 2:
No way found to prevent FreeFileSync from freezing the LINUX System.
Work around: uninstall FreeFileSync on LINUX and use Meld and Grsync instead. No as handy as FreeFileSync but working with no prblems.
therube
Did that come from a repo or from FFS directly?
So I take it that any run of FFS will cause a system freeze?
I.e., 1 single file, from 1 directory, & sync that to a different directory.
(And it does actually complete, though locks you up - that's weird.)
Are you able to run FFS in some sort of VM & have it lock up the system itself, & gather some debug information from there, assuming it hangs the VM?
