Browsing for folder (Not Responding)
cro-mag
I've never used freefilesync before so I can't tell you if it was working before or not. All I know is that anytime I click browse to select a file or folder either in freefilesync or RealTimeSync, the Select folder window opens but everything is grey and it basically locks the program up.
Can you send me a process monitor trace when this happens?
