Question
LAM
I keep getting a notification:
First:
The following folders are significantly different. Please check that the correct folders are selected for synchronization.
Then:
Some files will be synchronized as part of multiple folder pairs.
To avoid conflicts, set up exclude filters so that each updated file is included by only one folder pair.
How do I fix this situation? Thank you.
- Check that the correct folders are selected for synchronization
- set up exclude filters so that each updated file is included by only one folder pair
LAM
Yes, but how do I do that?
