Filtering by Keyboard Shortcut
bbbd2423
When I use freefilesync, I need to filter a lot of folder to not to be synced. Space or Alt-Down works great, but they are all temporary. Next time I run the comparison, it forgets these settings.
Therefore, the only viable option is to right click and exclude via filter and selecting the folder location. It's perfect except, it is a very slow process and I would like to use keyboard.
I wish we can set the shortcuts. But for me, space or Alt-Down would have been much more useful for this purpose.
What can I do to improve my workflow?
Define your In- and Exclude Filter rules ones.
Then simply save your sync configuration (Save as) a *.ffs_gui file.
This also saves Filter rules.
Next time simply open that saved sync configuration and there you are.
bbbd2423
Next time simply open that saved sync configuration and there you are. Plerry, 21 Mar 2026, 10:46
probably i wasn't clear, sorry.
Filters are saved, yes. No problem with that. But there is no shortcut for filters. Then it's several clicks per folder/file.
I am looking for a shortcut for filtering OR a way to save the settings of the mentioned temporary measures (such as Space or CTRL down.)
Plerry is right, or you are explaining incorrectly
bbbd2423
Plerry is right, or you are explaining incorrectly xCSxXenon, 21 Mar 2026, 19:08
Do you know shortcut for filtering? No.
You have couple of shortcuts to exclude a folder temporarily. But those are not saved for next comparison.
Those shortcuts for temporary In- or Exclusions exist because they are temporarily, which by nature means that they will not and are not intended to be saved or retained.
For In- or Exclusions that need to be saved or retained,
• for single items your "several clicks" are the one-time action of just two clicks; first right-clicking the item, hoovering over "Include via filter" or "Exclude via filter" in the context menu, and then left- or right-clicking the desired type/format of the filtering.
Creating shortcuts for the different available options would require six different shortcuts.
• for multiple items, after selecting those multiple items, your "several clicks" are again the one-time action of two clicks; first right-click on any of multiple the selected items, and then in the context menu left- or right-click "Include via filter <muliple selection>" or "Exclude via filter <muliple selection>"
