FileSync not syncing files
Lighthope
Setup FileSync to sync files in my "junk" folder on my c: drive. (Yes, that is what it is called.)
Saving out to d: drive.
No sync takes place. I create a new file in junk folder and it isn't copied over.
Post screenshots of your FFS window and sync settings
Lighthope
Post screenshots of your FFS window and sync settings xCSxXenon, 18 Apr 2026, 05:07
Attached.
Lighthope
It's working. File updates are taking longer than the advertised time in "idle time". That's what threw me.
From the RTS Manual page " ... RealTimeSync waits until a user-configurable idle time has passed with no further detected changes, then runs the command line."
So, your RTS command line (i.e. your FFS Compare en Sync job) will only start its Compare at earliest the RTS idle time after you changed a file.
