How to save a single file
How do you save a single file that is located in a folder containing many files?
Change your Include Filter from the default * (=everything) into just the file you want to copy.
The simplest way to achieve this in a correct way is by running (just) a Compare , then select and right-click that specific file and via the context menu Include that file.
It's really easy. My problem was: how do I exclude the rest? Thank you very much!
