OOM in Windows and Linux
skimax
I am doing a File Content Comparison between my local files and an FTP server and FFS will reliably get killed by Windows and Linux after a few minutes. Please fix this 😭
Screenshot show memory usage at 16GB and climbing!
Linux logs:
[Sun Jul 12 08:47:42 2026] Xwayland invoked oom-killer: gfp_mask=0x140cca(GFP_HIGHUSER_MOVABLE|__GFP_COMP), order=0, oom_score_adj=200
[Sun Jul 12 08:47:42 2026]  oom_kill_process.cold+0x8/0x91
[Sun Jul 12 08:47:42 2026] [  pid  ]   uid  tgid total_vm      rss rss_anon rss_file rss_shmem pgtables_bytes swapents oom_score_adj name
[Sun Jul 12 08:47:42 2026] oom-kill:constraint=CONSTRAINT_NONE,nodemask=(null),cpuset=/,mems_allowed=0,global_oom,task_memcg=/user.slice/user-1000.slice/user@1000.service/app.slice/app-org.kde.konsole-26161.scope/tab(26173).scope,task=FreeFileSync_x8,pid=26556,uid=1000
[Sun Jul 12 08:47:42 2026] Out of memory: Killed process 26556 (FreeFileSync_x8) total-vm:199741452kB, anon-rss:26999332kB, file-rss:6188kB, shmem-rss:852kB, UID:1000 pgtables:385936kB oom_score_adj:200
[Sun Jul 12 09:18:36 2026] gmain invoked oom-killer: gfp_mask=0x140cca(GFP_HIGHUSER_MOVABLE|__GFP_COMP), order=0, oom_score_adj=0
[Sun Jul 12 09:18:36 2026]  oom_kill_process.cold+0x8/0x91
[Sun Jul 12 09:18:36 2026] [  pid  ]   uid  tgid total_vm      rss rss_anon rss_file rss_shmem pgtables_bytes swapents oom_score_adj name
[Sun Jul 12 09:18:36 2026] oom-kill:constraint=CONSTRAINT_NONE,nodemask=(null),cpuset=/,mems_allowed=0,global_oom,task_memcg=/user.slice/user-1000.slice/user@1000.service/app.slice/app-FreeFileSync@b45686666e19446babf0408fc5bed70c.service,task=FreeFileSync_x8,pid=52321,uid=1000
[Sun Jul 12 09:18:36 2026] Out of memory: Killed process 52321 (FreeFileSync_x8) total-vm:200509440kB, anon-rss:27071456kB, file-rss:16kB, shmem-rss:456kB, UID:1000 pgtables:387400kB oom_score_adj:200
therube
_x86_x64, does that mean it is a 32-bit process?
Are you able to run the 64-bit version?
If so, does that work without OOM?
skimax
I just installed the Linux version at https://freefilesync.org/download.php so whatever that installs is what I am running.
skimax
Running: file /opt/FreeFileSync/FreeFileSync
Shows:
/opt/FreeFileSync/FreeFileSync: ELF 64-bit LSB executable, x86-64, version 1 (GNU/Linux), statically linked, stripped
