I sync from local PC to Network Device.
the sync itself works fine but when need to delete something on the network folder ther is always a warning
"The Recycle Bin is not available for "\\Hostname\path\\path\path\folder".
"Ignore it and permanently delete it every time the Recycle Bin isn’t available?"
I could set to ignore it but that is not the prefered solution.
Trashcan not found
But setting deletions to be permanent is not what I want especialy when there is a trashcan on the destionation file system.
