Old folders are not deleted when the maximum is reached.
I have a backup folder that is mirrored with a server's save folder. Every two days, the FreeFileSync batch file is executed via the Windows Task Scheduler. Existing data is moved to versioning folders; a maximum of 5 versions(folders) should be kept, with the oldest being deleted thereafter.
The problem: The older versions(folders) are not being deleted.
I would appreciate any help; thank you.
Here are some more screenshots.
Versioning Maximum doesn't work
Versioning deletes files from your Versioning locations.
It does not delete folders (once those become empty).
So, in your use case with the naming convention Time Stamp [Folder] (Zeitstempel [Ordener]) and "Limit file versions" set to a Maximum of 5, a file gets deleted from a timestamped folder (or one of its subfolders) once 5 more recent previous versions of that file exist in timestamped versioning folders with a more recent timestamp (than the timestamped folder the file gets deleted from).
Once a timestamped folder (or any of its subfolders) becomes empty, because of all files it used to comprise 5 more recent previous versions exist in any more recently dated timestamped folders, such then empty timestamped folder does not get deleted.
Note that the setting reads "Limit file versions", not "Limit file/folder versions".
Its main purpose is to prevent that the total data size of your Versioning location(s) keeps growing, as more and more previous versions of files are retained.
The data-size of multiple empty folders is generally neglectable.
This behavior is identical to what FreeFileSync does in synchronization locations.
If a left- or right-side base location or any of its subfolders becomes empty due a synchronization action, such then empty folder does not get deleted.
Thanks for the reply
Okay, I misunderstood that then.
So, it isn't possible to use versioning on the mirrored folder (`Saves_Backup`) to generate a copy that gets stored in the versioning folder (`Saves_Backup_Versionierung`)—where the oldest copy is deleted once there are more than five copies in the folder?
Yes, that's possible, but then you need to select Time Stamp [File] ((Zeitstempel [Datei]?) under "Limit file versions", not Time Stamp [Folder] (Zeitstempel [Ordener]).
In that case all previous versions of a given file are saved into the same folder (using the folder tree stucture relative to the left- and right base location. The most recent previous version is then saved under its original name, earlier version under the original name with a date addition.
In your case a maximum of 5 previous versions will be retained in one and the same folder.
That's not true. Empty folders *are* deleted by Versioning.Versioning deletes files from your Versioning locations.
It does not delete folders (once those become empty). Plerry, 19 Sep 2026, 10:56
You're misunderstanding "maximum". This is maximum version count per file, not "number of syncs".Old folders are not deleted when the maximum is reached. BergTal, 19 Sep 2026, 10:02
