FFS Crashes when I start File Synchronization. I have tried versions 6.8, 6.7 and 6.6 (portable and installation).
I am running Windows 7 64 bit. FFS used to work fine on my system.
However after formatting and re-installing Windows it no longer works. Does FFS rely on any libraries or something like .net?
I tried running in batch mode and enabling logging. It crashed, however the log was empty.
FFS Crashes on Win7 64bit
Does FFS create a crash dump file automatically? Is the crash reproducible and what are the steps? If yes, can you send me a mini dump file created with Process Explorer for the FreeFileSync_x64.exe process?
How do I know if FFS creates a crash dump file?
How to reproduce the crash (crashes every time for me):
-add folders to sync (or load profile)
-click on synchronize
(start synchronization now? pops up)
-click on start
(synchronizing... pops up)
-and then before any files are synchronized it crashes and the "stopped working
dialogue show:
>Problem signature:
Problem Event Name: APPCRASH
Application Name: FreeFileSync_x64.exe
Application Version: 6.8.0.0
Application Timestamp: 53db7540
Fault Module Name: FreeFileSync_x64.exe
Fault Module Version: 6.8.0.0
Fault Module Timestamp: 53db7540
Exception Code: c000041d
Exception Offset: 00000000004540f3
OS Version: 6.1.7600.2.0.0.256.48
Locale ID: 13322
Additional Information 1: b266
Additional Information 2: b2666c2904ab99423e8ff5e8900bb706
Additional Information 3: 7814
Additional Information 4: 7814dd7ed07b930bb4ccd791359cd3e5
I have attached a mini dump file (I made the dump after FFS crashed)
I have also added a screenshot.
[Attachment was removed! File name: FreeFileSync Dump.DMP (572395 bytes)]
-click on start
dialogue show:
>Problem signature:
Locale ID: 13322
If there are no files to synchronize or I deselect them no crash happens.
And synchronization completes showing the completed dialogue as normal.
(see attached screenshot)
[Attachment was removed! File name: no crash.png (583811 bytes)]
I noticed I didn't do the dump from the x64 process. Here is the correct
dump file
[Attachment was removed! File name: FreeFileSync_x64.dmp (1391749 bytes)]
dump file
FreeFileSync crashes at the following assembly instructionI noticed I didn't do the dump from the x64 process. Here is the correct
dump filetristan-heuer
000000013FAC40F3 vpsrlq xmm3,xmm0,34h
That's from the AVX2 instruction set and your CPU doesn't seem to support it. What CPU do you have?
My CPU is Core i5-4670.
Yes, seems I don't have SP1. I recently re-installed windows and though I installed all the updates through Windows Update. It didn't however, so I manually checked for updates and am installing now.
After getting SP1 I'll let you know if that fixes it.
I have installed SP1 and FFS works now.
Thanks for your help.
