FreeFileSync hangs after starting it
webmaster33
FreeFileSync hangs after starting it.
Does anybody met this problem?
I noticed this since last few version updates.
Is the hang permanent or is is just some kind of lag? If permanent, can you send me a process minidump file for analysis? Start Process Explorer, right-click on FreeFileSync_x64.exe, Create Dump, Create Full Dump.
If it's a lag, then a Process Monitor trace should help: http://technet.microsoft.com/en-us/sysinternals/bb896645.aspx
