unable to start after moving the ffs_gui
ptoche
The app crashed repeatedly on start-up after I had moved the location of the ffs_gui. On Mac OS X Mavericks, go to: Library -> Application Support -> FreeFileSync and open the GlobalSettings.xml with a text editor to delete the offending paths manually. Problem solved.
ptoche
and 6.10 app not working at all for me ("invalid something specification" error message), but 6.9 still works.
Can you post screenshots of the error messages you are seeing?
ptoche
Can you post screenshots of the error messages you are seeing?Zenju
Sorry Zenju, I downgraded to 6.09. Today I downloaded 6.10 again and clicked to launch it: nothing happens, no error message, the program is not launched, nothing...
You can try to start it from command line: execute
FreeFileSync.app/Contents/MacOS/FreeFileSync
manually, then you should at least see *something*.
The app crashed repeatedly on start-up after I had moved the location of the ffs_gui. On Mac OS X Mavericks, go to: Library -> Application Support -> FreeFileSync and open the GlobalSettings.xml with a text editor to delete the offending paths manually. Problem solved.ptoche
Do you have by chance your old GlobalSettings.xml that would allow me to reproduce the problem?
ptoche
Would you explain that more slowly please? Thanks!
ITs-MacBook-Air-2:Downloads PatrickT$ cd FreeFileSync_6.10_Mac_OS_X_64-bit
ITs-MacBook-Air-2:FreeFileSync_6.10_Mac_OS_X_64-bit PatrickT$ sudo FreeFileSync.app/Contents/MacOS/FreeFileSync
Password:
sudo: FreeFileSync.app/Contents/MacOS/FreeFileSync: command not found
Password:
sudo: FreeFileSync.app/Contents/MacOS/FreeFileSync: command not foundptoche
So the "FreeFileSync.app/Contents/MacOS/FreeFileSync" file is missing? This explains already why double-clicking the app does not work. Where did you download the .zip archive from?
ptoche
So the "FreeFileSync.app/Contents/MacOS/FreeFileSync" file is missing? This explains already why double-clicking the app does not work. Where did you download the .zip archive from?Zenju
Here, as usual:
https://freefilesync.org/
ptoche
If I right-click on FreeFileSync.app and select "Show Package Contents", the FreeFileSync file is there inside MacOS.
Just tested on OS X 10.9.5:
correctly starts FreeFileSync. OTOH the "FreeFileSync" binary is in fact existing in the released package. So it seems that - for whatever reason - it was missing in your test above.
ptoche
correctly starts FreeFileSync. OTOH the "FreeFileSync" binary is in fact existing in the released package. So it seems that - for whatever reason - it was missing in your test above.Zenju
Probably some weird thing on my system. I'll wait for the next release to see how goes... Thanks Zenju!
