New Feature request : Synchronize on modification
Hi there first of thank you for great software. I use it daily, its very handy. The one thing that i miss in free file sync is sync on modification feature. Any plan on including this feature in near future? It will be a great addition to this awesome software.
You mean like RealtimeSync?
Yes type of background syncing
No, Zenju means there is already a utility included with FFS that allows for sync on changed files. It's called RealtimeSync.exe and is included in this package.
oh ok I get it. I will try it thanks :)
np
Thanks for all and for the very good software. I will ask you if it's possible implement in the new version the possibility to use a Rsync protocolo.
My regards
Pietro
My regards
Pietro
