I have created ICONS for more than 300 folders in my original drive.
Then I sync'd it with the back up drive, all the files where transferred
successfully but when surfing the back up drive, to my horror, I realized all
the updated icons where not there..
How can I fix this bug!? I did a synchronization that copies NEW and UPDATED
files. I consider assigning and icon to a folder an update, why wasn't copied
then to the back up drive?
I dont want to re do the icon assignation (each icon is personalized) again to
the other drive nor in the future, is there a way for freefilesync to do it?
ICONS ARE NOT UPDATED WITH SYNC.
