problem with gui files
ivostoykov
Here is the problem I faced installing last version as a portable application
on Windows 7 32 bit.
[404, Invalid URL: https://skydrive.live.com/redir.aspx?cid=1866e379b544744f&resid=1866E379B544744F!618&parid=1866E379B544744F!154&authkey=!AAXz1aQ3wu0NGuU]
ivostoykov
ivostoykov
Sorry but image is not displayed here is the link [404, Invalid URL: https://skydrive.live.com/redir.aspx?cid=1866e379b544744f&resid=1866E379B544744F!618&parid=1866E379B544744F!154&authkey=!AAXz1aQ3wu0NGuU]
umbertob67
Hello!
I have the same problem with new version.
Saving the xml with the new FFS version migrates the configuration: viewtopic.php?t=839
ivostoykov
thank you - works. Just the message is misleading, thought
ivostoykov
same should be done with batch files...
