right-click context menu on list hooking to external text diff tool
After I found this tool, I started to use it and in general it is great! However, once and again I get into a state where I accidentally modified the same code files on two different machines and when I see an unanticipated copy direction, it would be great to be able to right-click on an item in the "to synchronize" list and choose "Compare..." which can be configured to send both copies to WinMerge or even WinDiff as one does in TortoiseSVN.
Tools > Options > customize context menu:
Enter a new command line:
"..\WinMerge\WinMergeU.exe" "%item_path%" "%item2_path%"
From the help menu:
The first entry is executed when double-clicking a row on main grid or pressing ENTER while all other entries can be accessed via the context menu shown after a right mouse click.
From the help menu:
Crap! I missed that! Thank you!!!!
