feature request: filename comparison only
8bar
I wish I had more flexibility in how FreeFileSync does its file comparisons. For example, when my phone auto-backups its camera photos, the copy is makes has a different date, and not just a one-hour difference. When I compare the files on my phone to the backup versions, FreeFileSync reports that all files are different.
I wish I could specify that file comparisons are to be based on filename only. Is there a way to do that now? If not, can that feature be added to the list?
Since version 7.9 FreeFileSync supports a Compare by file size.
8bar
Thank you!!!
