If a filter is added to an existing profile (and Mirror is being used), what happens to files/folders on the right-hand side that have been filtered? Are they just ignored and left as is, or deleted to make it match the left-hand side?
For example, if a filter is added to exclude the folder "Test" and it already exists on the right-hand side, what will happen to the "Test" folder on the right-hand side on the next sync?
Adding Filter to an Existing Profile?
Please could this be confirmed? Many Thanks.
Current handling is as follows:
viewtopic.php?t=248
viewtopic.php?t=248
Thanks for your reply Zenju.
