I'm using FFS to sync a folder between 2 macs through a gigabit Ethernet network, but somehow only getting transfer speeds up to about 25MB/s, that often can fall down to 10MB/s or less for several seconds. Copying the same files that would be synced manually from the Finder results in full ~100MB/s speeds, finishing the transfer of 10GB of files in <2 minutes instead of 8-10.
Any idea what could cause that? I could reproduce with all of 8.0, 8.1 and 8.2.
Slow transfer speed over network on Mac
This might still be an issue. Currently running FFS 9.3 and sync between two MACs. Transfer speed is ~35 MB/s with average file size of 2 GB. However, when I start copying files within finder at the same time (and about the same size), I easily hit 110 MB/s which would the maximum of my 1Gbit LAN connection.
Any hint to solve this issue would be most welcome.
I am too experiencing sloooow transfer. Running FFS 9.3 on a Mac Server (10.9.5) with an external Promise Pegasus2 R6 RAID attempting to mirror to a Buffalo Terastation 51210R. Ran the compare, took a while but it was about 4TB so expected. Starting syncing, ok speed, expected it to take about 24 hours but 3 days later speed had reduced to a crawl (<20KB/sec). Stopped it, reran the compare, about 800GB remaining, set it off again, good speed, ten minutes later back to <20KB/sec. 24 hours later, currently running at 15KB/sec with 390 days remaining to copy 780GB!!!
Neither the Mac or the Terastation are under any sort of load, CPU, IO etc all low. Any ideas?
I've made a few tests and it seems there is indeed a speed difference between FFS and say Finder, which is suprising considering that FFS has a similar implementation like "cp". Unless... Finder does some proprietary internal tricks that cp does not...
Do you find a speed difference between cp and Finder?
Ok, so i opened two finder windows, one from the source - the RAID and the other for the destination - new NAS server and dragged a 9GB folder across. This took about two minutes.
I then opened a terminal session and "cp'd" a similar 9GB folder from the same source to the same destination folders. This again took about 4 minutes (same folder size but considerably more items).
Both of these are acceptable to me. I have had FFS running this morning for just under 3 hours and it has copied very little at around 150KB/sec - reporting 30 days to copy the remaining 765GB.
Ok, so maybe a bit longer than 30 days now... :-(
Just to show...current state of copying with FFS
Copying some of the files via Finder
Seems the issue has been fixed:
viewtopic.php?t=4808
