Update from 8.2 to 8.3 fails (Win7/32)
jwjr
Problem signature:
Problem Event Name: APPCRASH
Application Name: FreeFileSync_8.3_Windows_Setup.tmp
Application Version: 51.1052.0.0
Application Timestamp: 56961f62
Fault Module Name: KERNELBASE.dll
Fault Module Version: 6.1.7601.23392
Fault Module Timestamp: 56eb2fb9
Exception Code: 0eedfade
Exception Offset: 0000845d
OS Version: 6.1.7601.2.1.0.256.48
Locale ID: 1033
Additional Information 1: 1175
Additional Information 2: 1175e305eed774c7b3e475b39441d49c
Additional Information 3: d053
Additional Information 4: d05384104e17e926973b0f98c130baec
Thanks!
Can you send me a crash dump file for the "FreeFileSync_8.3_Windows_Setup.tmp" process? With some luck I should be able to find the root of the problem:
https://freefilesync.org/faq.php#crash
jwjr
Sorry - I'm away from that 'puter for a week. :(
jwjr
Latest version also crashes, during the agreement scroll. The ZIPped dump is 62M, and cannot be emailed to the address in the FFS "Info" box.
jwjr
Based on another thread, I tried disabling Bitdefender temporarily, and the install completed successfully.
BD was reporting "an infected item in C:\Users\Me\AppData\Local\Temp\ns08082391\xxxxxxxx_stp\setup.exe. Virus name: Gen:Variant.Adware.DealPly.50."
"xxxxxxxx" was 8 hex numbers - "1990C7BD" for the latest version of the installer.
8.3 installed and working fine now.
