RealTimeSync at Startup
srjones67
I see that by design, when RTS starts up or a drive is inserted, it runs the command line specified. Is there a way to bypass this initial run? I just want RTS to execute the command line if a file has truly changed. Can you help?
srjones67
Hello? Anyone?
There is no way to disable this initial scanning. On the other hand there aren't any real drawbacks to this behavior. Even if the drives are actually in sync then this first result is buffered by the OS and the next comparison will mostly read buffered data.
