Disable Global Settings for specific batch job
ardi_26
Is it possible to disable or enable a global option for specific job?
For example I have checked the global settings "Copy NTFS permission" and every batch job copies NTFS permission. However I would like for a different batch job to disable NTFS permission copy. IS it possible?
Regards,
Yes, see "5. Use a different GlobalSettings.xml file":
https://freefilesync.org/manual.php?topic=command-line
