I synced a folder with programs and install files (from left to right)
Then ran an Syncing analysis immediately thereafter with the same two folders, now FreeFileSync wants to update 1779 install files like .dll, .sys, .ax, .cpl, .irc etc back again to from the right to (the original) left
This bug is caused cause the first run, where FreeFileSync copied files from the left to a new folder on the extern Backup drive, the program has copied the date of the runtime and not the files' original dates
But I am glad of keeping the original dates - so what to do?
Updated in wrong direction caused by incorrect date copying
The same thing is showing with some ISO files - which also not have the original date
Maybe this bug? https://freefilesync.org/faq.php#different-after-sync
MAyby I will give it a try, Thanks
Its solved and yes the guilty part was Comodo, Thanks
