I want to be able to move files from my computer to my nas. After they are synced to the NAS i want to delete the files on my computer. Is there anyway to do this?
Also how can I run this on a schedual? Lets say I want this to run at midnight every night automatically
Is there a way to move files then delete?
To schedule a backup, you will need to save the batch file and when you set up your Task Scheduler, you would select the batch file to run and have it for the program to run, then for additional arguments (select the path to the FreeFileSync.exe) that will get you started. Note when you are scheduling Tasks be descriptive as possible so this will be easier when you have over 20 different tasks that are scheduled.
