Possible to Ignore Folder Structure
skyerjoe
Does Free File Sync ignore the Folder structure when two Dirrctories will be compared ?
I have some same Files but in other Folders as on the counterpart side.
regards john
No, FFS respects the folder structure,
both during comparison and during syncing.
skyerjoe
oh ok
coud i bypass these ? may you know an alternative ?
regards john
therube
Depending on your sync type & needs, 'Detect Moved Files' may work for you, https://freefilesync.org/manual.php?topic=synchronization-settings.
skyerjoe
Hello @therube
Thanks for helping
I think this won' work , cause i have some folders and i want to compare first and the sync it in an way without duplicates.
So the best bet is an tool that is able to ignore the folder structure.
may an combination of tools like duplicate handling and sync functions will working better for my purpose ..
Does someone has any further clues ?
Thanks in Advance
regards john
skyerjoe
Hello
For me i found a solution. May someone helps too...
1. Sync All Folders with an Reference against each other with Free File Snyc which are have similar Folders and Files.
2. I use DupeGuru on the Reference Folder after the syncs to destroy all Dupes.
regards John
