NOT possible to compile ffs 8.7 for 32 AND 64 bit!!!
wdsm
does anybody know why ffs 8.7 does not compile?
boost 1.62.0
wxgtk 3.1.0
webkitgtk2 2.4.11
zenxml 2.4
gcc 6.2.1
g++ -std=c++14 -pipe -DWXINTL_NO_GETTEXT_MACRO -I../.. -I../../zenXml -include "zen/i18n.h" -Wall -O3 -DNDEBUG `wx-config --cxxflags --debug=no` -DZEN_LINUX -pthread `pkg-config --cflags gtk+-2.0` -c algorithm.cpp -o ../Obj/FFS_GCC_Make_Release/ffs/src/algorithm.o
In file included from file_hierarchy.h:25:0,
from algorithm.h:11,
from algorithm.cpp:7:
fs/abstract.h: In static member function ‘static bool zen::AbstractFileSystem::havePathDependency(const zen::AbstractPath&, const zen::AbstractPath&)’:
fs/abstract.h:60:45: error: ‘warn_static’ was not declared in this scope
warn_static("remove after migration")
fs/abstract.h:62:5: warning: no return statement in function returning non-void [-Wreturn-type]
make: *** [Makefile:100: ../Obj/FFS_GCC_Make_Release/ffs/src/algorithm.o] Error 1
thank you
frasou
Same problem here.
Did you find the solution?
dev-libs/boost-1.56.0-r1
sys-devel/gcc-4.9.3
x11-libs/wxGTK-2.8.12.1-r1
x11-libs/wxGTK-3.0.2.0-r2
dev-qt/qtwebkit-4.8.6-r1
dev-qt/qtwebkit-5.6.1
net-libs/webkit-gtk-2.4.11-r200
ildar_prophet
@Zenju , I see that too.
Do you have any idea why?
fs/abstract.cpp:81:61: error: 'warn_static' was not declared in this scope
warn_static("evaluate: consequences of stale attributes")
fs/abstract.cpp:85:36: error: 'streamOut' was not declared in this scope
bufferedStreamCopy(*streamIn, *streamOut); //throw FileError, X
eRCaGuy
@Zenju, same problem here when compiling on Ubuntu 14.04 with:
FFSync source 9.7
gcc 7.2
Any idea how to get it to compile? The Ubuntu 14.04 repository only has up to version 7.7 or so so I'm trying to compile from source to get the latest FreeFileSync version.
UPDATE: I just opened a new thread here: viewtopic.php?t=4941
