Dear all,
Every time the daylight saving time change is applied (i.e., twice a year) FFS decides that all the files are different so it sepnds several hours to do the synchronising.
Is there anyway around this?
Daylight Saving Time
There are plenty topics on this very subject in this forum. Or see e.g.
http://ask-leo.com/why_do_file_timestamps_compare_differently_every_time_change.html
In short:
* Use non-FAT formatted storage media
(i.e. using UTC rather than, like in FAT, using local machine time)
* Use the option to ignore files with a +/- 1 hour timestamp
(see the help file)
In short:
(see the help file)
