FreeFileSync 8.9 Crashes w/ MTP devices
ugoplatamia
When syncing/comparing between files on disk and a MTP device (Android, Nexus 5X), the application crashes.
bernique
Same for me. Any way to download v8.8?
Can you try the following version and see if the problem persists?
http://www.mediafire.com/file/t5b5h8ap9lrastb/FreeFileSync_8.9_Windows_Setup.exe
bernique
It lasted longer, but it crashed as well.
Alright, then we need to dig a little deeper. Can you send a crash dump file (if it wasn't created automatically already)
https://freefilesync.org/faq.php#crash
Marios Panayiotou
Hello people! Same problem here. I just upgraded from V8.8 to V8.9 and FFS crashes during comparison of a local directory and my Windows Phone (MTP device). How can we find V8.8 and go back until problem gets solved?
I've found a bug that is likely responsible for the crashes. Is the issue solved with this version?
c72578
@Marios: Just in case, FileHippo provides previous versions of FreeFileSync for download, e.g. FreeFileSync_8.8_Windows_Setup.exe
ugoplatamia
It looks like the issue is solved w/ Zenju's build. Thanks!
bernique
Solved for me as well. Thanks a lot!
Marios Panayiotou
Yes, the issue is solved with Zenju's version. Thanks a lot!
HawkTroy
I'm having the same problem, but the new version Zenju posted has expired on MediaFire. Anyway I can get it?
