Warning : Recycle Bin
I have the Recycle Bin turned off for my external USB backup drives. This generates a warning in the log file each time, and the log file title mentions there's a warning inside. That means each time I run a batch and check the logs, I have to open them all to make sure the warning is only in regard to the recycle bin and nothing else. Is there a way around this? Either not logging the recycle bin turned off as a warning, or not including this specific warning in the title of the log file?
Using a deletion handling other than "recycle bin" will avoid the warning.
