can't install FFS on Lubuntu 16.04 32 bit
ulliani
This is the full message with URLs
Hallo
I've been happily using FFS on variour ubuntu machines and never had a problem - excellent piece of software, thank you! Now I can't install it from the ppa in an older pc, with Lubuntu 16.04.1, 32 bit. This is what I get (it's in Italian , I hope you'll understand the gist anyway):
me@eeepc:~$  sudo add-apt-repository ppa:freefilesync/ffs
 This is the official FreeFileSync repository for Ubuntu. It is recommended to use this to keep your FreeFileSync tool easily updated.
((deleted part with hyperlinks))
Premere [INVIO] per continuare o Ctrl+C per annullare
gpg: portachiavi "/tmp/tmpsdmcyqk2/secring.gpg" creato
gpg: portachiavi "/tmp/tmpsdmcyqk2/pubring.gpg" creato
gpg: richiesta della chiave 715BE097 dal server hkp keyserver.ubuntu.com
gpg: /tmp/tmpsdmcyqk2/trustdb.gpg: creato il trustdb
gpg: chiave 715BE097: chiave pubblica "Launchpad FreeFileSync .deb" importata
gpg: Numero totale esaminato: 1
gpg:               importate: 1  (RSA: 1)
OK
So it looks that there are no problems adding the repository and retrieving the key.
me@eeepc:~$ sudo apt-get update
Ign:1 http://ppa.launchpad.net/freefilesync/ffs/ubuntu xenial InRelease
Trovato:2 http://archive.ubuntu.com/ubuntu xenial InRelease
Ign:3 http://ppa.launchpad.net/freefilesync/ffs/ubuntu xenial Release
Trovato:4 http://archive.ubuntu.com/ubuntu xenial-backports InRelease
Ign:5 http://ppa.launchpad.net/freefilesync/ffs/ubuntu xenial/main i386 Packages
Trovato:6 http://archive.ubuntu.com/ubuntu xenial-security InRelease
Ign:7 http://ppa.launchpad.net/freefilesync/ffs/ubuntu xenial/main all Packages
Trovato:8 http://archive.ubuntu.com/ubuntu xenial-updates InRelease
Ign:9 http://ppa.launchpad.net/freefilesync/ffs/ubuntu xenial/main Translation-it_IT
Ign:10 http://ppa.launchpad.net/freefilesync/ffs/ubuntu xenial/main Translation-it
Ign:11 http://ppa.launchpad.net/freefilesync/ffs/ubuntu xenial/main Translation-en
Err:5 http://ppa.launchpad.net/freefilesync/ffs/ubuntu xenial/main i386 Packages
  404  Not Found
Lettura elenco dei pacchetti... Fatto
W: The repository 'http://ppa.launchpad.net/freefilesync/ffs/ubuntu xenial Release' does not have a Release file.
N: Data from such a repository can't be authenticated and is therefore potentially dangerous to use.
N: See apt-secure(8) manpage for repository creation and user configuration details.
E: Impossibile recuperare http://ppa.launchpad.net/freefilesync/ffs/ubuntu/dists/xenial/main/binary-i386/Packages  404  Not Found
E: Impossibile scaricare alcuni file di indice: saranno ignorati o verranno usati quelli vecchi.
Here I get a number of error messages about the repository's authentication, which then prevent me from installing FFS (the message is that the programme can't be found).
I've tried to look for these error messages on this forum, but I couldn't find any answer. I would greatly appreciate any help. I've also downloaded the 32bit version for Debian, but I'm not sure it would be ok for my system, and in any case when I extract the file I can't find any file with the .deb extension and hence gdebi can't open the file named 'freefilesync'.
Thanks a lot
The launchpad repository is currently unmaintained, however you can download the 32-bit Debian release from https://freefilesync.org/download.php
