I'm very happy with FFS, I use 8.9 version.
I encounter a randomly error when backing up data to my synology nas using SFTP. (SFTP is way more fast than SMB on my desktop PC)
Sometimes, an error popup appears and says "libssh2_error_timeout" (15 seconds timeout). If I press the retry button, it's ok and the comparison continues. Then, the error pops other times and I have to press retry on every popups messages to continue the comparison.
It's a little annoying !
Regards
FFS 8.9 - SFTP timeout
I second that. Is it possible to add configurable option to set sftp timeout? That would be awesome. I need to increase it to at least 30-60 sec, due to heavy load on the server. Thank you!
I can donate for such an option !
Timeouts for FTP and SFTP connections can now be entered in the cloud folder picker: viewtopic.php?t=5664
