Das Privileg "SeSecurityPrivilege" kann nicht gesetzt werden.
Fehlercode 740: Der angeforderte Vorgang erfordert erhöhte Rechte. (AdjustTokenPrivileges)
With the previous version everything was working fine, but with the new version not at all.
System windows 7 64 Bit
Im working as administrator
please help
heinz
Change Freefilesync 6.14 -> 6.15
Is this the *full* error message?
Die Berechtigungen von "E:\Schiltknecht\ES\Schule\SL Liste Bewerbungen.xlsx" können nicht gelesen werden.Is this the *full* error message?Zenju
no this is the full error message!
Disable menu->global settings: copy ntfs permissions, and you're good.
thanks a lot - now everything is working as beforeDisable menu->global settings: copy ntfs permissions, and you're good.Zenju
