i try to sync 1 folder in my local lan with the same in my local PC
OS: Windows 8.1
i want to use RealtimeSync to update in realtime in 2 directions.
But when i run RealtimeSync and do Start it close in systemtry and it duplicate the icons more and more evry 10 seconds and i Must disconnect User before all my memory and CPU going full.
Any ideas how to close the "n" processes after it synched?
i do something wrong in settings?
It looks like you made RealtimeSync start itself in the command field each time.
danielsan73
I click start only 1 time then RealtimeSync auto hide into system try and automatically a new process start evry 10 seconds ,
i never touch nothing. Do it all alone.
after 10 min i need to disconnect user to stop it all.
Okay, the command line is incorrect and making RealtimeSync call itself. See the help file chapter "RealtimeSync" for more infos about how this tool works.
danielsan73
let me try to delete all and redo from blank
danielsan73
very good now it work
my mistake was create a batch from RealtimeSync and save it
then calling it from command line editated manually
making batch from FreeFileSync and save it and then load it from RealtimeSync it work
