First i want to say "Hi" to ALL. Hope You can share yuor knowledge about FreeFileSync.
I study manuals and topics from forum but i did not find clear answer.
Hope you can help me.
1. Operating Systems Support
In FreeFileSync there is no information that supports Windows Server 2012.
Do you know if it works on this OS?
There is no information that FreeFileSync supports Windows10 either. Do you know if it works on Win10?
2. I in main problem i have one folder, which i want to backup - let's say every day at 08:30pm.
Every day i want to create new folder with current day and time and copy all file from that folder to the new one, which every day will be created.
I am aware that i must you some batch file, which will be run from Windows Task Scheduler.
I am able to write script to create new folder with current date & time but i have no idea what i should do with FreeFileSync to copy my foder to the new one.
Is my thinking correct or there is easier way to achieve that?
Any advice will be much helpfull. Thank you.
Copy one folder to another - scheduler
