FreeFileSync 9.0 FTP option don´t work with my WD MyCloud
lmmlv
When i use use the FTP option in my WD MyCloud, he give me the error 550 (file not found). When i configure, i see in the directory tree all my directory.
If i use an FTP software to connect to the WD MyCloud, i don´t have any problems (below, is the log from the FTP client).
"Connecting to xpto.sytes.net , 18 abr 2017 11:51:23
< 220---------- Welcome to Pure-FTPd [privsep] [TLS] ----------
< 220-You are user number 1 of 10 allowed.
< 220-Local time is now 11:54. Server port: 21.
< 220 You will be disconnected after 10 minutes of inactivity.
> USER admin
< 331 User admin OK. Password required
> PASS (hidden)
< 230 OK. Current restricted directory is /
> SYST
< 215 UNIX Type: L8
> PWD
< 257 "/" is your current location
> TYPE A
< 200 TYPE is now ASCII
> PASV
< 227 Entering Passive Mode (89,114,253,45,130,180)
> LIST
< 150 Accepted data connection
< 226 3 matches total
! 205 bytes received/sent in 0 seconds (6612 Bytes/sec)
> CWD /Serviexper
< 250 OK. Current directory is /Serviexper
> TYPE A
> PASV
< 227 Entering Passive Mode (89,114,253,45,130,181)
> LIST
< 226 6 matches total
! 471 bytes received/sent in 0 seconds (29437 Bytes/sec)
> QUIT
< 221 Logout.
Connection closed"
Can you help me ?
Best Regard´s
Can you provide me with (test-) credential for this server?
lmmlv
Yes, no problem... send me your email
It's shown at the bottom of the FreeFileSync homepage.
lmmlv
Just send you the email with the credential.
Analysis so far:
The server is running Pure-FTPd and the server request mlst / fails with 550 Can't check for file existence. But more generally: all requests using an absolute path of the form ""mlst /folder/file" fail with 550.
Interestingly this error is dependent from CWD (current working directory): If the CWD is not "/" then the error above does not occur in combination with absolute paths. => clearly a Pure-FTPd bug.
The question is if there is a workaround...
Not that it helps, but it is a known issue with WD MyCloud:
https://community.wd.com/t/mycloud-ftp-server-gives-550-error-to-mlst-command/175979
FreeFileSync works with Pure-FTPd now! Here's the new beta version:
http://www.mediafire.com/file/ehv67n6mtwj6exj/FreeFileSync_9.1_beta_Windows_Setup.exe
lmmlv
Primary test indicate that is working fine (don´t give me anymore the error 550, unless the CWD is /. This is in line with my FTP Client. He makes the same thing)
When he finish the syncronization, he give me the following message:
It´s not possible to alter the modification data to "ftp://xpto.pt/test/LGP970/USB_Driver/LGUnitedMobileDriver_S4981MAN37AP22_ML_WHQL_Ver_3.7.2.exe.ffs_tmp."
Server does not support the MFMT command.
It´s not possible to alter the modification data to "ftp://xpto.pt/test/USB_Driver/LGUnitedMobileDriver_S4981MAN37AP22_ML_WHQL_Ver_3.7_MTKWHQL.zip.ffs_tmp."
I thing this happen because the way FTP handles with data/time (it always copy the data and create it with the data of the FTP server). Is there a way to workaround with this ?
Another thing is the comparation between computer and FTP server data. Is there a way to shadow the option "Data and File size" when we use the option FTP ? (That option in FTP don´t make any sense and may confuse some users)
You may ignore the warning message. However most FTP servers nowadays support MFMT, so a compare by "date and size" makes sense.
marcerisson
Same problem here : viewtopic.php?t=4295
Same cause maybe ?
I'll try with the 9.1 beta
marcerisson
Ok after having tried with v9.1, I'm still having issues, especially with special characters like "#" :
Cannot open directory "ftp://192.168.1.11/home/Internal Drive 2 - Data - D/Documents/Visual Studio 2015/Code Snippets/Visual C#".
CURLE_REMOTE_FILE_NOT_FOUND: RETR response: 550
550 Visual C: No such file or directory [curl_easy_perform]
Ok after having tried with v9.1, I'm still having issues, especially with special characters like "#" : marcerisson, 23 Apr 2017, 00:11
Confirmed. I'll post an update on this thread: viewtopic.php?t=4292
jacorem
Hi Zenju!
Thanks for the awesome software. I've tried some other software before yours, but they didn't work so well.
I have too a WD NAS. Actualy I'm using SFTP to run the synchronization, but I would like to move to a more (un)secure protocol, so my NAS could be a bit more protected from external attacks. Can I try too the 9.1 beta? Actualy I cannot access this link.
[link removed due to forum policy] Zenju, 20 Apr 2017, 21:15
Thanks again,
Jacopo
Can I try too the 9.1 beta? Actualy I cannot access this link. jacorem, 25 Apr 2017, 15:43
I've fixed the beta link above.
lmmlv
I tested the FTP option working with 80Gb of information in several trees and, for now, is working fine. I have only one question that i don´t discovery if it´s an error or something else:
I have one file that give me an error, i deleted in the NAS and in the source, and the error still there... the error is:
"Deleting file "ftp://192.168.0.10/antonior/Copia do Servidor/Serviexper/antonio/portatil/MONICA/03-12-2004/plano nacional de saúde 12-2003.pdf_sid=mOojxaIfnCs&mbox=INBOX&charset=escaped_unicode&uid=11&number=2&filename=plano nacional de sa�de 12-2003.pdf.ffs_tmp"
[17:26:39] Info: Cannot delete file "ftp://192.168.0.10/antonior/Copia do Servidor/Serviexper/antonio/portatil/MONICA/03-12-2004/plano nacional de saúde 12-2003.pdf_sid=mOojxaIfnCs&mbox=INBOX&charset=escaped_unicode&uid=11&number=2&filename=plano nacional de sa�de 12-2003.pdf.ffs_tmp".
CURLE_QUOTE_ERROR: QUOT command failed with 550
550 Could not delete /antonior/Copia do Servidor/Serviexper/antonio/portatil/MONICA/03-12-2004/plano nacional de saúde 12-2003.pdf_sid=mOojxaIfnCs&mbox=INBOX&charset=escaped_unicode&uid=11&number=2&filename=plano nacional de sa�de 12-2003.pdf.ffs_tmp: No such file or directory [curl_easy_perform]
-> Automatic retry in 10 seconds..."
The error said "550 Could not delete" but the file is not there anymore.
If i change the destination from "ftp://192.168.10/..." to "\\192.168.10\..." don´t give me the error.
Is this a bug ???
If i change the destination from "ftp://192.168.10/..." to "\\192.168.10\..." don´t give me the error. lmmlv, 28 Apr 2017, 17:04
Are you able to reproduce this error or ideally able to provide me with ways to reproduce on my end? FFS should not show an error about failing to delete a file when that file does not exist.
robleenheer
Praise for this awesome product!
However, MFMT problem here too, FTP-ing to a Windows IIS FTP server (under my own control).
Apparently, IIS has a modified implementation of the MFMT command, from what I read on the odd fora.
Are you going to support IIS FTP?
I'm running FFS v9.3 now.
