Hi there,
Is it possible not to sync the same files twice? I have FreeFileSync configured as shown on the screenshot. New files from the source folder will be synced to the target folder. For example, I have data09.txt on the source folder. I run a sync that copies the file to the destination folder. Then I delete the file off the destination folder. For the next sync, I don't want data09.txt to be copied over again as it has already been done so once. Thank you in advance for any advice!
Maya
Is it possible not to sync the same file twice?
