Hello guys,
is it possible set freefilesync to copy files from a folder on a remote ftp (not sftp) folder, and then move the local file to another local folder?
It seems to work with the two ways options, after I move the file on the remote server... but what if I sync from 2 different machines?
The "update "option doesn't move anything...
Thank you! :)
move file to the remote ftp folder, then move local files to another folder
