Windows: ability to use volume names instead of absolute paths
rnbrito
Hi!
In Windows, I've found "another backup solution" that solved my issue when a removable drive (or any other type) receives another drive letter, so, when I need to refer to it, I may use a "portable path" in the following format (thats how "the other solution" calls it):
=VolumeName:\folder1\folder2
Ref: https:(slash)(slash)www.goodsync.com(slash)manual#portable_paths
(I was restricted to post a valid URL here because this is my first post. You may search for "goodsync manual portable paths")
That could be a good solution, on Windows or on any other system that can handle "volume/drive/disk" names.
On Ubuntu, for example, when you plug-in a disk, the udev daemon usually mounts it in /media/username/volume-name.
Consider that feature could be used on FreeFileSync and on RealTimeSync as well.
What do you think about that?
rnbrito
Perfect. That's it. Sorry for not looked into the manual.
Thanks!
