The commands Replace or Timestamp give the same result in the revisioning
folder, files with timestamp.
Anyone?
Thanks.
7.0 Comand Replace not working
You mean the time stamp is not attached to files with naming convention "time stamp"?
Looks like "Naming convention" under "Versioning" is stuck in the "Time stamp" setting regardless of option chosen. If "Naming convention" is set to "Replace" under "Synchronization Settings" > "Versioning" it adds time stamp to saved file version name.
What do you mean with "stuck"?
It's like it always set as "Time stamp" even if "Replace" is set. It show which option I chose ("Time stamp" or "Replace"), but always does "Time stamp".
Let's say:
1. I set it as "Time stamp", during version file creation program create file in format: "Folder\File.doc YYYY-MM-DD hhmmss.doc" And that's what expected.
2. I set it as "Replace", during version file creation program create file in format: "Folder\File.doc YYYY-MM-DD hhmmss.doc" -while "Folder\File.doc" is expected.
Let's say:
Thanks for this feedback! This is a small thing to fix, but a big functional problem in this specific scenario, so I've updated the 7.0 version just now instead of waiting until the next release.
Thank you so much for the speedy update!
