How do I get the portable version
I am a donation coder contributor (and have my key), How do I get the portable version? I can't find my original email. I can update my installed version but don't know how to get/generate the portable.
Look in the relevant FAQ section:
https://freefilesync.org/faq.php#portable
Run setup and under installation-type select "portable" ...
Same problem here.
I just donated and downloaded from the link received with my "Donation Received" e-mail. However, I am not given the choice for a portable install?
If you open FFS and go to help > about, you can click donation details to get to your donation page. From there, you can find the portable edition next to the regular installers
I didn't even get the Donation Version from that email link, only the normal version :(
