Cannot move file Error
TekieG
This is the error I get, I am using Windows 8.1 x64 and the 9.4 Beta version. the 9.3 release doesn't get past the black spaces some of the folders have between words. It scanned without a problem.
Cannot move file
"ftp://192.168.1.248/PV_Out/DATACENTER_1-1/MadisonWI_DatAir/Block/Mosaic/PVV_Nadir_Ortho_15cm/meta/autoseam/20160417_A_S01_Cam1_006451-0417161313029-CAM1_to_20160417_A_S02_Cam1_006596-0417161318068-CAM1.c75b.ffs_tmp" to
"ftp://192.168.1.248/PV_Out/DATACENTER_1-1/MadisonWI_DatAir/Block/Mosaic/PVV_Nadir_Ortho_15cm/meta/autoseam/20160417_A_S01_Cam1_006451-0417161313029-CAM1_to_20160417_A_S02_Cam1_006596-0417161318068-CAM1.offset".
CURLE_QUOTE_ERROR: QUOT command failed with 550
550 /PV_Out/DATACENTER_1-1/MadisonWI_DatAir/Block/Mosaic/PVV_Nadir_Ortho_15cm/meta/autoseam/20160417_A_S01_Cam1_006451-0417161313029-CAM1_to_20160417_A_S02_Cam1_006596-0417161318068-CAM1.c75b.ffs_tmp: No such file or directory [curl_easy_perform]
I tried both Mirror, and update synchronization. If I press ignore it'll jsut give me the same error for the next file. Could the file path be way too long?
Quite possible, other than that I do not see anything special. Is this error only reproducible for long file names?
TekieG
I'm not sure, this only happens when I use the FTP portion. if I use the regular Computer HDD to computer HDD on the network, I don't get the error. (I tried the FTP for transfer as I wanted to test the transfer speed of million of small KB files FTP vs HDD to another HDD on the network).
Edit: As I look at it more and looked at the files themselves, the other files which has similar PATH length do get copied. :/ Sorry about that I guess it could be the files.
Of course this could be another manifestation of this bug here:
viewtopic.php?t=4575
