How to work with source and destination folder with different names?
rogerfsp
The program only keeps the destination folders, when the source has the same name. For example: if source = C: \ DOCS and destination = D: \ DOCS, it works fine. but if source = C: \ DOCS and destination = D: \ BKP \ DOCS the DOCS folder is deleted!
Thanks!
Gianni1962
Left C:\DOCS and Right D:\BKP\DOCS should work.
What DOCS folder is deleted?
Please don't put unnecessary blanks in the paths to avoid adding confusion.
rogerfsp
Gianni,
I have not used blanks in the paths. They only appeared here in the message on the forum.
The folder DOCS that is deleted is the target (D:\BKP\DOCS). It works once, then in the following synchronizations, the BKP folder is empty.
Thanks!
Gianni1962
What variant you have set-up in "Synchronization Settings"?
rogerfsp
Gianni,
I believe that now I understand the program. The Batch processes are working fine.
Thanks!
