BUG: automatic backup
PackElend
Ungültige Befehlszeile:
File: "d:\Users\Stefan\Downloads\FreeFileSync_9.4_[Donation_Edition]_Windows_Setup.TX-71821161HM5604545.exe"
Arg: /silent /dir=D:\Programme\FreeFileSync /install_type=local /autoupdate
Fehlercode 216: Die Version von %1 ist mit der ausgeführten Windows-Version nicht kompatibel. Überprüfen Sie die Systeminformationen des Computers, und wenden Sie sich anschließend an den Herausgeber der Software. [ShellExecuteEx]
Sounds like a broken executable, most likely caused by AV (e.g. Avira is known for causing this kind of trouble).
PackElend
I have Panda AV but it didn't throw any warning
Frank
I had exactly the same problem with the last three version updates.
In my download folder I can find two files:
FreeFileSync_9.7_[Donation_Edition]_Windows_Setup.exe
FreeFileSync_9.7_[Donation_Edition]_Windows_Setup.key
Both only 1 kB in size ...
When I download the ZIP manually from the Website I get to files:
FreeFileSync_9.7_[Donation_Edition]_Setup.exe
FreeFileSync_9.7_[Donation_Edition]_Setup.key
Perhaps a naming problem - so that the automatic download couldn't find the files on the server ?
Both only 1 kB in size ... Frank, 17 Jan 2018, 09:59
What is the content of these files?
Frank
Both containing:
"Error: Html parameter validation failed."
I've fixed the issue! Can you try the auto-update again? (but clean up the broken old files first)
Frank
Unfortunately there is no update available at the moment - as I've updated manually ...
I'll check that with the next update and keep you updated !
Thanks for you help !
Frank
Just a short reply:
It's working perfect now !!! Thanks a lot !
